Incomprehension pin activation but remains in comment in the dts (on Config Tool for i.MX)
Hpot
I'm trying to activate pins (on my IMX8MQ), such as MIPI_CSI1. Firstly, why is it grayed out by default?
Then when I activate it, I route all the corresponding pins, but these are added as comments in the pin_mux.dts, instead of being in the fsl, pins with a hex code.
Thanks in advance,
Best regards.
Alejandro_Salas
Hello @Hpot
What is the Config Tools version what are you using?
Best regards.
Salas.
Hpot
Config Tools for i.MX v15.0
Alejandro_Salas
Hello @Hpot
Th commented lines belong to YAML SETTIGS for Config tools. As MIPI signals have dedicated pins there is not necessary to config "IOMUX".
Best regards.
Salas.
Hpot
But then how can I configure this type of pins? Are they “stuck” in this configuration?
