In dts file how to set pad register addres
1,486 次查看
veeranjaneyulug
Hi all
we used linux kernel 3.14.28 .In kernel dts file imx6qdl-sabresd.dtsi file .
How to configure new gpio pin by using dts file .
MX6QDL_PAD_KEY_COL3__HDMI_TX_DDC_SCL 0x4001b8b1
how to set the address can you any body please explain me.
标签 (4)
4 回复数
1,219 次查看
igorpadykov
Hi veeranjaneyulu
addresses are set in ..arch/arm/boot/dts/imx6q-pinfunc.h
linux-2.6-imx.git - Freescale i.MX Linux Tree
1,219 次查看
veeranjaneyulug
Thanks for your reply .but In that file how can i calculate reg address .please can you explain one example .
Thanks & Regards
veeranjaneyulu
1,219 次查看
igorpadykov
#define MX6QDL_PAD_KEY_COL3__HDMI_TX_DDC_SCL
0x210 0x5e0 0x890 0x2 0x1
1,219 次查看
veeranjaneyulug
Thanks for your reply and explanation than input_reg,mux mode,input value how can i find out values .please can you give the explanation.
Thanks & Regards
veeranjaneyulu
