Imx6ul use 1280*800 display, how many frames can be displayed
1,009 次查看
liangmu
Dear ,
I use the imx6ul evk baseline, and the screen resolution is set to 1280*800, and how much is the frame rate set at this time? Will the shadow be displayed?
851 次查看
joanxie
for hardware side, refer to the material,
  • Display Resolution
Support up to WXGA@60fps with rich UI & application
Support up to 1080p@60fps with limited UI update*
Maximal pixel rate: 150 MP/sec
for the max, you can set 60
for software side, I got document as below:
The LCD driver controller is ili9341, resolution is 320x240, bpp is 16.When SPI bit per word is 32, the performance is 30fps.
so this depends what bpp and what bsp version you use.
851 次查看
liangmu
Thinks for your replay!
In our baseline code,i have find the lcd resolution set to 60fps.
