IPU issue during system bootup
1,045 次查看
chaitanyadhere
Hello all,
              I'm using kernel version 3.14.28 and a custom imx6 solo board. I'm getting a log which is as follows:
Starting kernel ...
imx-ipuv3 2400000.ipu: WARNING: adapt panel end blank lines
I'm not able to see anything on the LVDS display. Our kernel command line is :
console=ttymxc3,115200n8 video=mxcfb0:dev=ldb,800x480M@60,if=RGB24,bpp=32 consoleblank=0 lpj=7905280 init=/early_init no_uart5_sdma nosmp quiet kernel=primary
Interestingly, if I remove the the quiet option from the above command line, the boot time increases by some 700 ms which is OK but the above issue mentioned in the log is not observed !!! Is it due to fact that the IPU is getting initialized too early ?
What can be the issue ? Kindly let me know.
Chaitanya Dhere
标签 (4)
698 次查看
Hi Chaitanya
seems this issue is specific for custom board and used configuration,
you can add delay before ipu initialization. Just for reference use below example
Patch to support uboot logo keep from uboot to kernel for NXP Linux and Android BSP (HDMI, LCD and L...
