IPG/PER clocks
IPG/PER clocks
2,969 次查看
vsiles
Senior Contributor I
Hi !
I've tried to search for the meaning of the 'IPG' acronym that one can find in several reference manual or in Linux source code, but I can't find a source. What does 'IPG' stands for ?
Also, I'm trying to fully understand the differences between the 'ipg' and 'per' clocks that most device have (for in Linux dtb). My understanding is that the 'ipg' clock drives the access to the device iomapped registers, and the 'per' clocks drives the device itself.
Am I right ?
Thank your for your explanation,
V.
标签 (3)
1,907 次查看
Hi Vincent
yes this is right. Seems 'IPG' relates to IPbus global clock (IP Bus Interface (AIPI)).
1,908 次查看
Hi Vincent
1,907 次查看
vsiles
Thank you !
