IMX8QM-MEK Power Management difference between Linux and Android
vinothkumars
Senior Contributor IV
Dear NXP,
I got observation when I try to send  suspend-to-ram command ( echo mem > /sys/power/state ) from Android and Linux
Suspend to Ram in Android OS,
      L4.14.98
      # echo mem > /sys/power/state
      Application Processor going to suspend and resumed automatically
Suspend to Ram in Linux OS,
      L4.14.78 & L4.14.98
      Application Processor going to suspend and wait for user press power key
Will you please give me the configuration or implementation to achieve the Linux level in Android ?
Thanks & Regards,
VinothS,
Vinothkumar Sekar
vinothkumars
Finally I found wake-up API from power driver and disable it for disabling the auto wakeup.
VinothS,
Vinothkumar Sekar
vinothkumars
VinothS,
Vinothkumar Sekar
smathe25
Hi ‌
Could you specify the driver you updated and changes you made to disable auto wake up.
vinothkumars
Sebimohan Mathew
Find my attachment.
Vinoth S,
Vinothkumar Sekar
smathe25
Thank you so much ‌
Have you ever tried GPIO pad wake up with some specific GPIO?
vinothkumars
Hi Sebimohan Mathew
Please find the document link,
iMX8QM-MEK: SUSPEND AND WAKEUP IN ANDROID 9 AUTOMOTIVE
Vinoth S,
Vinothkumar Sekar
siva_prabhakara
did u ever get any GPIO wakeup method to work?
smathe25
Follow this: How to add iMX8QXP PAD(GPIO) Wakeup . This worked for me
vinothkumars
Hi Sebimohan Mathew
I never tried with GPIO. But, some default wake-up already present.
Wake up done by following,
  1. A53 debug UART
  2. Power Key
  • WAKE-UP
    1. BUTTON
         By pressing the power-key SW3 (0.5s)
     2. DEBUG UART
         Enable debug UART wake-up
         # cat ./sys/devices/platform/5a060000.serial/tty/ttyLP0/power/wakeup
         disabled
         # echo enabled  > ./sys/devices/platform/5a060000.serial/tty/ttyLP0/power/wakeup
         TO WAKEUP
                  Press the ENTER Key 2 times
Vinoth S,
Vinothkumar Sekar
igorpadykov
Hi Vinoth
for Android supported power management one can refer to
sect.8.9 Power state configuration attached Android Guide.
from NXP Android documentation on link
Android OS for i.MX Applications Processors | NXP
vinothkumars
Hi ‌
=> power 1 2
I tried Power control from car MCU console
is working, But, Sometimes the system wakes up by itself.
Power control from car MCU consolePower control from car2 AP consoleComment
suspendpower 1 2echo "1 2" > /sys/devices/ platform/vehicle-dummy/ power_reqThe system disconnects from BT, waits for all tasks to be done, and then enter suspend mode. Press the power-on key to wake up the system. BT is connected again. Sometimes the system wakes up by itself.
Is there any possible to disable system wake up ?
Thanks & Regards,
VinothS,
Vinothkumar Sekar
igorpadykov
Hi Vinoth
one can look at power management differencies between android and linux
Linux Kernel and Android Suspend/Resume -blog archive
vinothkumars
Hi ‌
I validate the Linux L4.14.98 in imx8qm Mek board. There is no auto wake-up.
I compared the Linux pm driver source  with Android 9 automotive (L4.14.98) look like both are same.
Why android and Linux behaving differently when I write the power sate "echo mem > /sys/power/state " ?
Thanks & Regards,
VinothS
Vinothkumar Sekar
igorpadykov
Hi VinothS
because power management is different in linux and android as described below
vinothkumars
Thank you Igor for your quick reply,
Is it possible to configure Linux power management in Android ?
Thanks & Regards,
VinothS,
Vinothkumar Sekar
igorpadykov
Hi VinothS
this is general android question, suggest to post it on android forums:
Learn about our Developer community programs  |  Google Developers
vinothkumars
Thank you Igor for the reply.
Thanks & Regards,
VinothS,
Vinothkumar Sekar
vinothkumars
Hi Igore,
Thank you for the quick reply. I checked the document and thank you for the document.
I needs to send power 1 2  (=> power 1 2) from M4 console to suspend Application Processor , Am I right ?
Thanks & Regards,
VinothS,
Vinothkumar Sekar
