We ported the 88W8997 with SDIO interface for WLAN and got the mlan0 interface on ifconfig.
using iw command, we could able to scan and connect using mlan0 interface.
we got mlan0 and p2p0 interface got created.
while debugging the logcat, we are getting following on WiFI ON using UI.
07-19 13:28:09.088 370 370 E WifiHAL : Timed out wating on Driver ready ...
07-19 13:28:09.088 370 370 E android.hardware.wifi@1.0-service: Failed or timed out awaiting driver ready
07-19 13:28:09.088 370 370 E android.hardware.wifi@1.0-service: Failed to start legacy HAL: TIMED_OUT
07-19 13:28:09.089 552 635 E HalDevMgr: executeChipReconfiguration: configureChip error: 9 (, timed out)
07-19 13:28:09.089 552 635 E WifiVendorHal: Failed to create STA iface
07-19 13:28:09.089 552 635 E WifiNative: Failed to create iface in vendor HAL
07-19 13:28:09.089 552 635 E WifiClientModeManager: Failed to create ClientInterface. Sit in Idle
wifi related configuration settings are fine as below,
wifi.interface => mlan0
wifi.direct.interface => p2p0
Please share your inputs
