IMX8MM enabling MIPI panel driver for ILI9881C
1,515件の閲覧回数
zenith0123
I have been trying to integrate Ilitech ILI9881C MIPI panel on my IMX8MM custom board on Android 11 environment.
I have tried to change defconfig as following:
CONFIG_REGMAP=y
CONFIG_SYSCON=y
CONFIG_DM_RESET=y
CONFIG_RESET_DISPMIX=y
#CONFIG_VIDEO_IMX_SEC_DSI=y
CONFIG_DRM_MIPI_DSI=y
CONFIG_BACKLIGHT_CLASS_DEVICE=y
CONFIG_DRM_PANEL_ILITEK_ILI9881C=y
CONFIG_DM_VIDEO=y
#CONFIG_VIDEO_LCD_RAYDIUM_RM67191=y
#CONFIG_VIDEO_ADV7535=y
CONFIG_SYS_WHITE_ON_BLACK=y
CONFIG_DRM_PANEL_ILITEK_IK9881C=y
After that, Kernel build log seems that it not includes drivers for IK9881C panel.
How can I solve this problem?
Thanks in advance.
4 返答(返信)
1,501件の閲覧回数
igorpadykov
Hi Zenpei
one can try to use imx8mm-evk-rm67191.dts
https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm64/boot/dts/freescale/imx8mm-evk-r...
in driver set for ILI9881C specifc initialization sequence in struct cmd_set_entry mcs_rm67191[]
and timings in struct drm_display_mode default_mode :
https://source.codeaurora.org/external/imx/linux-imx/tree/drivers/gpu/drm/panel/panel-raydium-rm6719...
1,488件の閲覧回数
zenith0123
Hi Igor,
Thank you for the answer.
But unfortunately I'm not familiar to Linux/Android. Do you mind if you tell me how to apply changes you mentioned to the source codes and modify build in detail?Some pointers to reference documents is appliciated.
Thanks in advance.
1,462件の閲覧回数
ko-hey
Senior Contributor II
Hi @igorpadykov ,
I'm working with zenith0123 in this project.
Could you follow up his request ?
ko-hey
1,458件の閲覧回数
igorpadykov
Hi ko-hey
nxp has special service for help with porting drivers for customer needs  :  https://contact.nxp.com/new-prof-svcs-sw-tech
