IMX8MM - digital mic PDM input
1,736 次查看
shai_b
Senior Contributor II
Dear team,
My customer has the following inquiry about PDM interface on IMX8MM, They need to connect a microphone that outputs PDM. They think they need to change the MCLK & DATA to one the SAI5 inputs, can you advise if this the correct way to interface with MIC.
for the MIC datasheet please refer https://www.mouser.co.il/datasheet/2/218/knowles_corporation_know-s-a0002305576-1-1736216.pdf
Please find attached pic how they plan to connect it and advise us back.
Thanks in advance
Kind regards,
shai.b@telsys.co.il
标记 (2)
1,694 次查看
igorpadykov
Hi Shai
I believe connections on picture are correct, note "SAI5 inputs"
are just pads name, input should be provided to pdm module,
for example PDM_CLK is muxed on SAI5_RXC pad.
