IMX8M display rotation
Search instead for
raman_thapar
I am using a iMX8M mini EVK + LVDS panel (with a SN65DSI83 bridge). The panel has a hactive of 1024 and vactive of 600
I see the following in the logs
01-01 00:00:15.032  3130  3130 W display : mode.width   = 1024 px
01-01 00:00:15.032  3130  3130 W display : mode.height  = 600 px
What I need to do is rotate the display so that the longer edge is the height and shorter edge is the width? Can I get some help to identify the changes needed in both Linux and if needed Android to make the system always display content with height 1024 and width 600?
I have tried using the steps here
https://devtalk.nvidia.com/default/topic/1029340/android-development/configure-display-orientation-t...
which shows no change.
I tried using fbcon:rotate=1 which did not work (Also saw later that the imx8m reference manual mentions fb is no longer used "Frame buffer drivers are supported for i.MX 6 and i.MX 7 but not for i.MX 8")
I have spent a week look at different combinations so any pointers would be very helpful.
Thanks!
rizwanm
Hi ,
Could you please help us how to rotate the display Android 9.0 Pie (i.MX8 MINI)
raman_thapar
Does anyone have any ideas here?
I was able to use SurfaceFlinger to perform the rotation but I am still hoping to get something in the Kernel so that the rotation is performed during the boot up stage as well.
Bio_TICFSL
Hello Raman,
You can rotate the display by changing the weston.in file, as in the example below:
root@imx8mmevk:~# cat /etc/xdg/weston/weston.ini
[core]
# i.MX: Disable idle timeout
idle-time=0
backend=drm-backend.so
[libinput]
touchscreen_calibrator=true
[output]
name=DSI-1
mode=720x1280@60
transform=270
[screen-share]
command=/usr/bin/weston --backend=rdp-backend.so --shell=fullscreen-shell.so --no-clients-resize
raman_thapar
Thanks for the reply. That file does not exist on the system.
Also I would need a way to do this as part of the code/build so that once it is deployed the change takes effect at boot itself.
One other data point
When I try this command on the MIPI display it rotates fine
content insert --uri content://settings/system --bind name:s:user_rotation --bind value:i:1
This same command on the LVDS version has no effect.
edward_fu
Have you solved the problem? I have the same problem.
Bio_TICFSL
You can contact professional services
Design Services | NXP
