IMX8DX core A35 power supply
913件の閲覧回数
ceng_guanghui
Hello
        About IMX8DX core A35 power supply.See the datesheet as below
 Overdrive mode,the typ voltage is1.1V
 Nominal mode,the tye voltage is 1.0V
In the hardware design to choose one ,what's your suggestion
Thanks.
Zeng
790件の閲覧回数
neusch
What effect does the mode have for the lifetime ?
The effect at MX6 is impressive: Consumer 1,2GHz / Industrial 800MHz
Is ther any information about MX8 (overdrive/normal mode) ?
849件の閲覧回数
Yuri
  Depending on applications customer can use Overdrive or Nominal mode for VDD_A35 (Power
supply of Cortex-A35 cluster). For applications, where performance is the main requirement, the
Overdrive mode can be applied; for power saving - Nominal mode may be recommended.
Yuri.
