IMX6 Quad and Quad Plus 2 channel H/W encoding performance
1,206 次查看
ivyliu
We want to try 2 channel H/W encoding simulaneously with IMX6 Quad or Quad Plus with 1080P or 720P.
We will use H.264.
Could someone tell me what is the highest 2 channel H/W encoding simulaneously performance for both Quad and Quad Plus with 1080P and 720P?
Can they both be 1080P@30fps?
Thanks and Best Regards,
Ivy
标签 (2)
947 次查看
Hi Ivy
please check p.6 presentation for simultaneous encode performance
Q&A: MX6 VPU H.264 Dual Stream Encode Limits | NXP Community
i.MX6Q and QP have the same vpu module.
5 回复数
948 次查看
Hi Ivy
947 次查看
ivyliu
Hi Igor,
Thanks for your prompt reply.
Do you know what would be the maximum throughput when VPU is operating at 352 MHz?
Ivy
947 次查看
Hi Ivy
below link may be useful
Memory Reserved on i.MX6 for VPU
947 次查看
ivyliu
Hi Igor,
Thank you for your reply.
I will try to decrease the size.
Ivy
947 次查看
Hi Ivy
please check suggested presentation, it shows in brackets (vpu>300MHz)
