Hello!
I'm trying to communicate with a FPGA over EIM bus on i.MX 6ul. When I use Non Multiplexd mode,
the data can be send to D[15:0] correctly , but in Multiplexd mode, the data on D[15:0] is kept as 0x0020. I want to konw whether the D[15:0] can be multiplexed as address pins in in Multiplexd mode?
@chsdzczp
There is no such mode, where data bus signals i.MX6UL EIM_D[31-0] may be used
as address bus; only the EIM_DA[15-0] may be applied.
Yuri.
