I am using kernel 4.14.98 version in yocto . I am not able to see MXC drivers under graphic support May I know where to enable galcore drivers is there any device tree is needs to be written inorder to enable the galcore driver. could you please share the what and all info is needed to enable the galcore in my imx7ulp board
There is no MXC driver in 4.14.98 for graphics since use the drivers of the gpu itself, you can find the MXC for uart and PWM.
