I.MX7 power sequencing
846 次查看
NIKHITHAANTONY
In the datasheet of I.MX7 it is given that, VDD_SOC should powerup before NVCC_DRAM and NVCC_DRAM_CKE. So whether it can be done by software. In hardware design, whether we need to take care anything for delaying NVCC_DRAM and NVCC_DRAM_CKE
5 回复数
828 次查看
NIKHITHAANTONY
Then How VDD_SOC will become high before NVCC_DRAM and NVCC_DRAM_CKE.
822 次查看
in hardware. Use appropriate PMIC with power-up sequence compatible with i.MX7D datasheet
requirements.
814 次查看
NIKHITHAANTONY
We designed I.MX7 processor as per SABRE board. In that PMIC PF3000 is used.
So there will be correct power sequencing..right?
809 次查看
right
834 次查看
Hi NIKHITHA
>whether it can be done by software..
no
no need.
