I.MX23 Boot from SD
次の代わりに検索
1,301件の閲覧回数
johnsullivan
Hello, I'm developing a board using the I.MX23 and I want to boot from an SD Card. Do I need to write anything to the OTP memory to do this?
I am confused about the default behavior of the SD_POWER_GATE_GPIO and SD_POWER_UP_DELAY. Do most SD card require a power up delay? Or would I be fine without it? This board is for my own education so it does not need to be very robust.
タグ(2)
1,026件の閲覧回数
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
6 返答(返信)
1,027件の閲覧回数
CommunityBot
Community Manager
NXP Community!
1,026件の閲覧回数
igorpadykov
Hi john
two OTP bit fields in HW_OCOTP_ROM0 should be burned for SD boot:
1. SD_MBR_BOOT
2. SD_POWER_GATE_GPIO
Bitburner can be used during development.
IMX_OTP_TOOLS : A set of tools for managing OTP bits on the i.MX23 and i.MX28.
Contains BitBurner.exe, the otp_burner.py and BitInit.exe.
1,026件の閲覧回数
johnsullivan
Is it required that I burn any values? It would be much simpler if I don't have to write anything to the OTP memory.
1,026件の閲覧回数
igorpadykov
for OTP values please read Reference Manual.
Unfortunately it would not be simpler for you without
1,026件の閲覧回数
johnsullivan
Okay, how exactly do I write to the OTP memory? Can I use the debug UART or USB? I haven't been able to find this in the documentation.
1,026件の閲覧回数
igorpadykov
Bitburner can be used to write to the OTP memory
