How to work UART BT device on i.mx53 Android
Search instead for
brahman_river
Hi, All.
I'm working UART(RS-232C) Bluetooth device on i.MX53 Android Platform.
I tried to enable Bluetooth via configuration panel but didn't make it.
To use Bluetooth devices, is there any configuration needed against i.MX Android Package before building image?
VikramU_ng
Hi Takashi-san,
  Maybe this document helps <Anroid Bluez>
HTH.
daiane_angolini
hum.... I´m confused.
kernel only recongnize device after hciattach? Before that is there none message?
I was searching around and I found a lot of people working with bluetooth dongle with android uper that 1.6 without any special procedure.
Is there any clue on your logcat?
brahman_river
Hi Daiane,
I've found that a command "hciattach" was required to make the kernel recognize the device.
This command was successful on the PC Linux and Ubuntu i.mx53. But I didn't make it on Android platform.
This might be because the specified device was incorrect. I guess that is "ttymxcX".
Do you know what device the serial port is regarded as?
Takashi Kawamoto
daiane_angolini
oh. First step is your devices being recognized by kernel.
Connect you device on some PC, and see what´s the dmesg message for it.
Then, try to configure kernel to regocnize the same. You will need to be sure kernel version used can support it.
brahman_river
Hi Daiane,
When the BT device was connected, dmesg said nothing. So I think the Kernel couldn't recognize it.
The attached file is .config for the kernel.
Takashi Kawamoto
daiane_angolini
Can kernel recognize your bluetooth device? What does dmesg show?
brahman_river
Even the above option was added to BoardConfig.mk, Bluetooth could not be enabled with configuration panel.
I have no idea what to do further...
brahman_river
Hi Daiane,
Thanks for your prompt comment :)
According to the following page, it seems that an option "BOARD_HAVE_BLUETOOTH" shoule be enabled in BoardConfig.mk.
I'm now rebuilding the Android image.
Takashi Kawamoto
daiane_angolini
I´m guessing, but I believe you will need to include support for it on BoardConfig.mk (inside device/fsl).
I suppose kernel has support for your device.
