Hi All
Platform: i.MX8M-EVK
SW: Linux version 4.9.51-imx_4.9.51_imx8m_ga+g6df7474
An error occurred when adding the HDMI output parameter to the kernel parameter as follows.
uboot command line:
setenv mmcargs 'setenv bootargs ${bootargs} root=${mmcroot} rootwait rw video=HDMI-A-1:dev=hdmi,1920x1080@59.94,if=RGB24'
error message:
[ 1.474509] [drm] parse error at position 30 in video mode 'dev=hdmi,1920x1080@59.94,if=RGB24'
How can I fixed it?
Solved! Go to Solution.
Hi Felix
one can try with Demo Images
using attached Release Notes recommendations described in
Table 3. Kernel and device tree configurations:
fsl-imx8mq-evk.dts: for HDMI output
Table 4. Pre-built images :
Combined Boot Image, imx-boot-imx8mqevk-sd.bin-flash_hdmi_spl_uboot
Table 10. Common kernel boot parameters :
video kernel parameter: 1920x1080p60: video=HDMIA-1:1920x1080-32@60
The video must be set HDMI-A-1 not HDMIA-1.
