How to remove the print " NXP i.MX Release Distro 4.9.88-2.0.0 imx6slevk ttymxc0" from kernel logs"
搜索替代
721 次查看
sujay1
I'm using an imx6slevk board with yocto bsp, I observed that at the end of the kernel boot the line  NXP i.MX Release Distro 4.9.88-2.0.0 imx6slevk ttymxc0 is printed.
I changed the u-boot environment variable "console" from ttymxc0 to null
After which the kernel logs no longer appear but this line keeps printing as  NXP i.MX Release Distro 4.9.88-2.0.0 imx6slevk ttymxc0 and not  NXP i.MX Release Distro 4.9.88-2.0.0 imx6slevk null,
Where should I modify in the source to change it to null?
标记 (2)
602 次查看
karangajjar
Senior Contributor II
Hi Sujay S,
Please remove '\l' from /etc/issue file.
Refer to below link for more details:
Customizing your Logon with /etc/issue
Karan Gajjar
4 回复数
603 次查看
karangajjar
Hi Sujay S,
Karan Gajjar
602 次查看
sujay1
That worked fine than you Karan
602 次查看
karangajjar
Hi Sujay S,
We are happy to resolve your query. Thank you for marking the answer correct.
Karan Gajjar
602 次查看
Bio_TICFSL
ok
