How to put bootanimation.zip into the sources
nxp31
I have learned how to put bootanimation.zip into /system/media/ on the installed system or e.g. into out/target/product/evk_8mm/system/media/ in the android_build directory.
But how can I put it into the android sources, so it is placed into .../system/media during the build process?
Is there e.g. some binaries directory from where bootanimation.zip is copied to .../system/media
like described in the last paragraph of this instructions to the Digi Embedded for Android for the ConnectCore 6 ?
Change Android boot images
tpe
I successfully included boot animation in the source code build. I put my bootanimation.zip in 'device/fsl/common'. After that, you need to copy that file for your board. I am developing on the mek_8q so I changed the mek_8q.mk file in 'device/fsl/imx8q/mek_8q/mek_8q.mk'
Add a similar line like this:
PRODUCT_COPY_FILES += \
    device/fsl/common/bootanimation.zip:system/media/bootanimation.zip
tpe
Sanjay_Pandey1
For i.MX8QM MEK Evaluation Board (Android 11) following copy statement to be added in the "android_build/device/nxp/imx8q/mek_8q/mek_8q.mk" file.
#Copy Boot Annimation
device/nxp/common/bootanimation.zip:$(TARGET_COPY_OUT_SYSTEM)/media/bootanimation.zip
Please note the source folder : device/nxp/common/bootanimation.zip and destination : $(TARGET_COPY_OUT_SYSTEM)/media/bootanimation.zip
b45499
You can try to refer to this https://community.nxp.com/docs/DOC-330208
nxp31
Thank you.
I have seen this.
As said, I am able to install my own boot animation on the i.MX8 MM EVK.
The question is, how can I put the boot animation into the source code repository?
So that I can e.g. do a make clean and rebuild the system from the sources with my boot animation installed.
tpe
I'm having this same issue as well. Did you come up with a solution for this?
Thanks and best regards,
tpe
