How to make .bin from .elf
2,138件の閲覧回数
ko-hey
Senior Contributor II
Hi all,
I want to try DDR Stress test via JTAG interface with i.MX6SL.
According to the following link, user use elf file which is in ddr_stress_tester_jtag_vX.xx.zip and makes use of *.bin file output.
i.MX6/7 DDR Stress Test Tool V3.00
http://cache.freescale.com/files/training/doc/ftf/2014/FTF-SDS-F0170.pdf
I tried to convert from elf to bin file with following link but failed.
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0805bj/CACDFBIF.html
Could you tell me how to get a bin file to use DDR Stress Test via JTAG ?
[Background of the question]
I want to try DDR Stress test via JTAG interface and unzip a ddr_stress_tester_jtag_vX.xx.zip.
Then, I got .elf but those files exceeded capacity of internal RAM.
So I think I need to get bin file from it.
Ko-hey
3 返答(返信)
1,957件の閲覧回数
Yuri
   Using .elf with JTAG is quite reasonable way. The program in itself in .elf format
uses the same target memory as in just memory image in .bin. But usually it is needed
to perform system / memory initialization, provided by corresponding initialization script.
   Examples of the initialization script may be found in
ddr_stress_tester_v3.00\script\mx6sl\ directory
Yuri
1,957件の閲覧回数
ko-hey
Hi YuriMuhin_ng
Thank you for reply.
Do you say it doesn't need to convert to bin from elf file ?
Does it no matter that the elf file exceeds the capacity of internal RAM ?
Are the following steps correct ?
1. User runs DRAM init which is in ddr_stress_tester_v3.00\script\mx6sl\ directory.
2. User loads ddr_stress_tester_jtag_v3.00\ddr-test-uboot-jtag-mx6sl.elf
BR,
ko-hey
1,958件の閲覧回数
Yuri
 Files  .elf and .bin are really just different formats of the same code / data.
In .elf code / data are stored in records with headers, also additional information
is added, say for debugging. In .bin memory image is stored.
  If Your debugger can load and run .elf, using own loader, understanding .elf format - apply it.
Note - special command should be used to load .elf - it is not just copy image file to memory,
byte-to-byte, as for the .bin.
  Your steps are correct.
Yuri.
