How to include memtool in the core-image-base ?
Search instead for
matt67
Hello guys,
We are trying to include the memtool utilities from imx-test packages, but I can't figure out how to do it.
Hereunder is the content of my local.conf file :
MACHINE ??= 'imx6ulevk'
DISTRO ?= 'fsl-imx-x11'
PACKAGE_CLASSES ?= "package_ipk"
EXTRA_IMAGE_FEATURES = "debug-tweaks"
USER_CLASSES ?= "buildstats image-mklibs"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
STOPTASKS,${TMPDIR},1G,100K \
STOPTASKS,${DL_DIR},1G,100K \
STOPTASKS,${SSTATE_DIR},1G,100K \
STOPTASKS,/tmp,100M,100K \
ABORT,${TMPDIR},100M,1K \
ABORT,${DL_DIR},100M,1K \
ABORT,${SSTATE_DIR},100M,1K \
ABORT,/tmp,10M,1K"
PACKAGECONFIG_append_pn-qemu-native = " sdl"
PACKAGECONFIG_append_pn-nativesdk-qemu = " sdl"
ASSUME_PROVIDED += "libsdl-native"
CONF_VERSION = "1"
DL_DIR ?= "${BSPDIR}/downloads/"
ACCEPT_FSL_EULA = "1"
#IMAGE_INSTALL_append = "kernel-module-wilc1000 hostapd wpa-supplicant minicom"
IMAGE_INSTALL_append = " hostapd imx-test wpa-supplicant minicom kernel-dev"
DISTRO_FEATURES_append = " systemd"
#VIRTUAL-RUNTIME_init_manager = "systemd"
IMAGE_FEATURES_append = " tools-testapps tools-debug tools-sdk dev-pkgs"
I see the imx-test.ipk package correctly build in the deploy directory but not shipped in the final image. I can't figure out why. Any idea ?
See u
Tags (2)
jimmychan
I tried to build it again. The unit_test can be found in my new built image.
Here is my step:
1. MACHINE=imx6ulevk source fsl-setup-release.sh -b build-6ul-x11
2. Add IMAGE_iNSTALL_append = "imx-test" in the local.conf
3. bitbake core-image-base
After built succeed, unit_test can be found in build-6ul-x11/tmp/deploy/images/imx6ulevk/core-image-base-imx6ulevk.tar.bz2
matt67
Thanks finally it works !
jimmychan
Here is my step:
jimmychan
do you see the unit_test folder in your rootfs?
matt67
No I can't see it's not shipped in the final image.
See u
jimmychan
I tried to add  IMAGE_INSTALL_append = "imx-test"  in my local.conf. And then 'bitbake core-image-base' again. I can see the unit_test in the new core-image-base .tar.bz2 image.
Would you tell me which BSP are you using?
so, let me try to reproduce your issue on my side.
matt67
I use branch imx-4.1.15-1.0.0_ga of fsl-arm-yocto-bsp.git reopositorie, my target is imx6ul evk board.
See u
