In our linux user space we need to implement 78 microsecond timer callback to read spi data.
We had implemented the timer callback using timer_create, timer_start api's. But problem is timer doesn't running properly for microsecond until millisecond it's works fine.
Do you have any recommended solution to implement microsecond timer callback.
Thanks & Regards,
Vasu
