I am trying to write a sample media player on iMX6.
One of the primary objectives is to understand the synchronization between audio and video.
To accomplish this my application needs to get video PTS from decoder and the submit the corresponding
audio data to the AACPlus decoder API.
The VPU documentation does not mention any specifics about the timing information.
I am not sure but from what I understood, Gstreamer maintains its own clock and submits the data accordingly.
Please guide me on this front regarding AV synchronization.
Thanks in advance.
解決済! 解決策の投稿を見る。
Hi Subodh
I think you can look below and choose what is suitable
Hi Subodh
you are correct VPU does not maintain audio synchro
it is done in gstreamer . Please check timestamping API
gstreamer documentation below
http://gstreamer.freedesktop.org/data/doc/gstreamer/head/pwg/pwg.pdf
Hi Igor,
I want to write a native player around the vpu API, in that case what method would you suggest for AV Synchronization.
Hi Subodh
