I have signed image using scfw_tcm.bin (System Controller Firmware ),mx8qm(qx)-ahab-container.image (Security Controller Firmware),bl31.bin(ARM Trusted Firmware),u-boot.bin(U-boot binary).
now I want to flash image into board using emmc. Can you please tell me which command i should use.
pls refer to the chapter 4.5.13 How to build imx-boot image by using imx-mkimage of enclosed user guide,
For i.MX 8QuadXPlus, to build imx-boot image by using imx-mkimage, perform the following steps:
1. Copy u-boot.bin from u-boot/u-boot.bin to imx-mkimage/iMX8QX/.
2. Copy scfw_tcm.bin from SCFW porting kit to imx-mkimage/iMX8QX/.
3. Copy bl31.bin from Arm Trusted Firmware (imx-atf) to imx-mkimage/iMX8QX/.
4. Copy the SECO firmware container image (ahab-container.img) to imx-mkimage/iMX8QX/.
5. Run make SOC=iMX8QX flash to generate flash.bin.
6. If using OP-TEE, copy tee.bin to imx-mkimage/iMX8QX/ and copy u-boot/spl/u-boot-spl.bin to imx-mkimage/
iMX8QX/. Run make SOC=iMX8QX flash_spl to generate flash.bin
Hello joanxie,
Thank you for your reply.
1) I have build flash.bin from mkimage tool and signed it with using .csf from CST tool. now i have signed flash.signed.bin
2) I need to load this flash.signed.bin image into imx8qxp by using eMMC. which command i should used here.
previously I was using sudo uuu -b emmc_all imx-boot-.bin-flash .rootfs.wic
Can you please guide me which command i should use with flash.signed.bin on emmc.
