How to enable internal RTC of i.mx6ull
shaot
Hi, I would like to use internal real time clock of i.mx6ull.
However I could not enable it and when I use hwclock, then it displays as follows.
hwclock: can't open '/dev/misc/rtc': No such file or directory
In fact, nothing is found by "ls | grep rtc".
The device tree is defined as follows.
imx6ull.dtsi
snvs: snvs@020cc000 {
compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd";
reg = <0x020cc000 0x4000>;
snvs_rtc: snvs-rtc-lp {
compatible = "fsl,sec-v4.0-mon-rtc-lp";
regmap = <&snvs>;
offset = <0x34>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
snvs_poweroff: snvs-poweroff {
compatible = "syscon-poweroff";
regmap = <&snvs>;
offset = <0x38>;
mask = <0x61>;
snvs_pwrkey: snvs-powerkey {
compatible = "fsl,sec-v4.0-pwrkey";
regmap = <&snvs>;
interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
linux,keycode = <KEY_POWER>;
wakeup;
imx6ul-imx6ull-var-dart-common.dtsi
&snvs_rtc {
status = "enabled";
How can I use the internal RTC of i.mx6ull and use "hwclock"?
Labels (4)
igorpadykov
Hi Hirotoshi
one can test with Demo Image unit tests (folder../mxc_rtc)
imx-test
www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-test-5.7.tar.gz
i.MX 6ULL NXP EVK Linux Binary Demo Files
https://www.nxp.com/webapp/Download?colCode=L4.1.15_2.0.0_iMX6ULL&appType=license&location=null&Pare...
shaot
Thank you for your reply. However I do not use i.mx6ull EVK but I use other board.
So I have to edit my sources. Would you give me the source files not binary?
Or are there any register which should be editted to enable i.mx6ull internal RTC?
linda_zhang
Normally, if there is RTC driver, there will have below information when booting:
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
We are testing on our MYD-Y6ULX board.
