How to enable eth1 get IP automatically when kernel startup?
liuyonggang
Environment: Yocto
Platform: Imx8qxp
OS: Linux
Version: 4.14.98
There are two Ethernets (eth0&eth1) on my board.I have forbidden busybox first.eth0 can gets IP automatically when kernel startup.But eth1 cann't gets IP automatically when kernel startup.secondly,I have masked "obj-$(CONFIG_IP_PNP) += ipconfig.o" . But eth0 still can gets IP automatically when kernel startup.
I can't find config IP corresponding code.Can someone tell me which file?
BRs
Johnny
joanxie
maybe you can refer to the document as below:
https://community.nxp.com/docs/DOC-344765
liuyonggang
Hi Xie,
   I can't open the link which you provide. Can you send the document to me?My E-mail:liuyg13530885230@163.com.
Tks!
BRs!
Johnny!
joanxie
this document is about that  RMII PHY is NXP TJA1101, it output 50MHz REF_CLK to i.MX8QXP. what's your design? you use your own board or just imx8qxp board with base board? how about your dual ethernet?
liuyonggang
Hi Xie,
   My board is ES1.The two RGMII PHY chips are Marvell_88Q2110。I have already find where can enable eth0&eth1 to get IP
automatically.It in systemd/systemd/50-wired.network file.The content of the file is as followings:
[Match]
Name=eth0
[Network]
DHCP=ipv4
and I modify "Name=eth0" to "Name=eth*" .It can be okay.
Thanks all the same.
BRs
Johnny
