How to enable BT/WiFi with android-10.0.0_2.5.0 and imx8mq?
647 次查看
sethchen
Hi Sir,
I couldn't turn on WiFi/BT with a prebuilt Android Q image.
What should I do to config the 1CQ combo module (QCA6174)?
Cheers,
Seth
4 回复数
645 次查看
Zhiming_Liu
You can make menuconfig in kernel source to select BT/WIFI driver.
Zhiming
642 次查看
sethchen
Hi Zhiming,
Does it mean the default prebuild image package (android-10.0.0_2.5.0_image_8mqevk) doesn't config to support QCA6174 module?
Cheers,
Seth
631 次查看
Zhiming_Liu
Yes, bcm and qca  wifi is disabled in prebuilt images.
Zhiming
613 次查看
sethchen
Hi Zhiming,
Many thanks for your kindly reply.
The imx8mq EVK in my hand is still using 1CQ COB module. Does NXP provide any patch or document to activate this HW directly? Maybe latest EVK already migrate to 8997 module. Some developers are still using the old EVK.
Cheers,
Seth
