hi,
current I use IMX6ULL EVK to do development without any OS(like linux, RTOS and so on).
I use IAR build out hello world project with ram.icf. And then I use JTAG to download hello world.bin to QSPI flash. But it can not work when I config EVK to boot from QSPI.
my user story:
1. use IMX6ULL EVK to do development without linux;
2. build official SDK project with IAR;
3. download code to QSPI flash;
4. boot from QSPI flash and run code in DDR;
How can I do?
By the way, I want to use MFG tool to download code to QSPI flash refer to <Getting Started with MCUXpresso
SDK for i.MX 6ULL Derivatives>. But it failed to download. It always reset cause by POR.
another question, Is the Boot ROM code can be programed?
Solved! Go to Solution.
The MFG Tool download fail issue is fixed. current I can use MFG Tool to download hello world project to IMX6ULL EVK QSPI flash and boot from it.
