How to disable the fec2 from the devicetree in imx6ulevk
搜索替代
2,223 次查看
sourabhdas
I am using imx6ul-evk board, which has two ethernet ports. In our custom board, we will be having only one ethernet. So, I tried to disable the fec2 in the detree, by making status="disabled" in its entry.
I was getting the error on booting:
Configuring network interfaces... ifconfig: SIOCSIFFLAGS: No such device
Also the eth0 or eth1 interface was not comming on doing ifconfig.
Next I tried by removing the fec2 entry from the board devicetree file, and creating a mdio entry in fec1. This time on booting, I was getting:
fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:02, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
I am getting eth0 interface on doing ifconfig, but I am not able to ping ip of my pc.
Please suggest me something on this, on how to disable the fec2 from devicetree.
标记 (2)
962 次查看
sourabhdas
I solved the above issue. Actually the MDIO and MDC line of both the FEC's are same. So, when I was making the status of FEC2 as disabled, the pin muxing of MDIO and MDC was not happening. To solve this issue, i added these two lines in the enet1grp:
 MX6UL_PAD_GPIO1_IO07__ENET1_MDC     0x1b0b0
 MX6UL_PAD_GPIO1_IO06__ENET1_MDIO    0x1b0b0
962 次查看
Serpico
Hi Sourahb,
I know that is an old post, but now I've the same problem. I need to disable fec2.
Did you only added the MDIO and MDC lines in enet1grp? did you also move MDIO from fec2 to fec1?
Thanks in advance
Francesco
962 次查看
Carlos_Musich
Hi Sourahb,
Thank you for sharing your solution with us.
Carlos
