How to disable ethanviv driver and enable galcore vivante driver
ravicalm
How to disable ethanviv driver and enable galcore vivante driver could you please help me
Bio_TICFSL
The BSP uses galcore GPU driver by default available at /drivers/mxc/gpu-viv.
Additionally one can add the below line in local.conf
IMAGE_INSTALL += " kernel-module-imx-gpu-viv "
ravicalm
it is not enabled that's why I have posted so many questions on this with bsp version. please tell me what device tree will support and with corresponding configuration which helps me to enable galcore
