How to control the FCB?
搜索替代
764 次查看
eunseokjung
Hi all,
The community teach me a lot of things about Bootloader. My level is increased very sharply. Thank you very much.
Now, i understand what is Kobs-ng and how to use this.
But one thins is unclear. Relationships between FCB and Kobs-ng.
What i know that Kobs-ng can write FCB to the NAND.
How to control FCB by using Kobs-ng? I can't find control option in Kobs-ng.
Where can i find about this information?
Best,
Eunseok.
463 次查看
igorpadykov
Hi Eunseok
for example of kobs-ng usage please look at attached ucl.xml
from mfg tools, also may be useful to look at
AW: imx53 internal boot from NAND — Barebox
463 次查看
BiyongSUN
kobs-ng
kobs-ng version : [ 1.3 ] git hash (unknown)
ROM Version 3
usage: kobs-ng [COMMAND] [ARGS]
Where [COMMAND] is one of:
  dump [-v] [KOBS] ........................ Verify/dump boot structures
    -v .................................... Verbose mode
  imgverify [-v] [KEY] <file> ............. Verify image validity
  init [-v] [KEY] [KOBS] <file> ........... Initialize boot structure &
                                            install bootstreams
    -x .................................... Add 1k-padding in the head
    -n .................................... Dry run (don't commit to flash)
    -w .................................... Commit to flash
  update [-v] [KEY] [KOBS] [-0|1] <file> .. Update a single bootstream
    -0|1 .................................. Update specified bootstream #
  extract [-v] [KEY] [KOBS] [-0|1] <file> . Extract a bootstream from flash
    -0|1 .................................. Extract specified bootstream #
  [KOBS] boot structures config options
    --chip_0_device_path=<path> .......... Device of boot (default /dev/mtd0)
    --chip_1_device_path=<path> .......... The second chip in case of multichip NAND
    --search_exponent=<value> ............ NCB field (default 2)
    --data_setup_time=<value> ............ NCB field (default 80)
    --data_hold_time=<value> ............. NCB field (default 60)
    --address_setup_time=<value> ......... NCB field (default 25)
    --data_sample_time=<value> ........... NCB field (default 6)
    --row_address_size=<value> ........... NCB field (default 3)
    --column_address_size=<value> ........ NCB field (default 2)
    --read_command_code1=<value> ......... NCB field (default 0x00)
    --read_command_code2=<value> ......... NCB field (default 0x30)
    --boot_stream_major_version=<value> .. NCB field (default 1)
    --boot_stream_minor_version=<value> .. NCB field (default 0)
    --boot_stream_sub_version=<value> .... NCB field (default 0)
    --ncb_version=<value> ................ NCB field (default 3)
   [KEY] key management related options
        -d ............................... Use device key (OTP) (not yet supported)
        -z ............................... Use key of all zeroes (default)
        -k<hexadecimalkey> ............... Use hex key of 16 bytes
464 次查看
igorpadykov
Hi Eunseok
