Hi all,
We are now want to link a LCD panel to the i.MX6 quad with Linux or Android Operating System.
But the LCD panel is only support DE mode. So we must to modify the driver.
We have read the article "Different Display Configurations on i.MX35 Linux PDK", unfortunately, Linux with imx6 seems be different with i.MX35.
So what should we do? Anyone can help?
We do not have special app note how to configure displays for i.MX6 Linux,
sorry. The article "Different Display Configurations on i.MX35 Linux PDK" describes
main ideas and structures, used for display driver configuring in Linux.
For more information about i.MX6 Linux BSP specifics, please refer to
the corresponding BSP Porting Guide and Linux Reference Manual (IPU driver)
in Linux documentation (L3.0.35).
Yuri
Hi igor,
Thanks for your reply!
Where can I get the reference config?
Does it in the "IMX6_SABRE_SD_KK442_100_ANDROID_DEMO_BSP " or L3.0.35_4.1.0_ER_SOURCE_BSP package?
So much thanks!
Hi Guo
please look at attached Linux Manual sect.5.4 Source Code Structure
<ltib_dir>/rpm/BUILD/linux/drivers/video/mxc/ldb.c struct ipuv3_fb_platform_data sabresd_fb_data[]
<ltib_dir>/rpm/BUILD/linux/arch/arm/mach-mx6/board-mx6q_sabresd.c struct ipuv3_fb_platform_data sabresd_fb_data[]
Android has the same codes.
Hi igor,
Now I have read the "IMX6DQRM", and found that if using DE mode with high active(20.3.1 DCIC Control Register (DCICx_DCICC)),I need to change
DE_POL to value '0'. Am I right?
However, I don't know how can I the value of "uint32 sync" in "static struct fb_videomode video_modes"(/drivers/video/mxc/mxc_lcdif.c).
Any ideas?
Hi Guo
I think you should change
FB_SYNC_OE_ACT_HIGH to FB_SYNC_OE_ACT_LOW
or add it as in (just example):
static struct fb_videomode video_modes[] = {
/* NTSC TV output */
"TV-NTSC", 60, 720, 480, 74074,
122, 15,
18, 26,
1, 1,
FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT | FB_SYNC_EXT,
FB_VMODE_INTERLACED,
0,},
~igor
