How to change the QSPI NOR size
1,537件の閲覧回数
erickang
Dear All,
I want to know how to change the QSPI NOR Size.
Our development environment is like as below,
- Device/Board : i.MX6SX-SabreSD
- OS : Linux 3.10.53
- Nor Device : Micron N25Q512A13GF840F
Actually, default NOR in i.MX6SX-SabreSD is Micron N25Q256A13EF840,
the N25Q256A13EF840 is pin-to-pin with N25Q512A13GF840F.
We have to change the Size because of RootFS size.
Eric.
ラベル(3)
917件の閲覧回数
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
3 返答(返信)
918件の閲覧回数
CommunityBot
Community Manager
NXP Community!
917件の閲覧回数
igorpadykov
Hi Eric
one can change qspi size in configuration parameters, please check
IMX6SXRM Table 8-27 QuadSPI Configuration Parameters
also one can look at
Linux/Documentation/devicetree/bindings/mtd/partition.txt - Linux Cross Reference - Free Electrons
917件の閲覧回数
erickang
Hi Igor,
Thanks for your response.
I checked the "Serial Flash A1 size" in "Table 8-27. QuadSPI Configuration Parameters".
I think I will apply the changed Serial Flash Size if I apply the below 2 items.
Is this right?
1) Modify Serial Flash Configuration File
    - change qspi-nor-micron-n25q256a-config to qspi-nor-micron-n25q512a-config
    - modified contents
      . 4000000  /*sflash_A1_size=size in byte(hex) : 64MB = 512Mb = 0x0400.0000 */
      . 0   /*sflash_A2_size=size in byte(hex)*/
      . 4000000  /*sflash_B1_size=size in byte(hex) : 64MB = 512Mb = 0x0400.0000 */
      . 0   /*sflash_B2_size=size in byte(hex)*/
    - change cfg.ini in MFGTool
      . [variable]
        norconfig=qspi-nor-micron-n25q512a-config
2) Change Partition
    - change Partition in Linux boot command line or u-boot environment like as below,
       mtdparts=21e4000.qspi:1m(uboot),8m(kernel),1m(dtb),-(user)
Eric.
