How to calculate the constant value used by the imx_init_calib () function in imx_thermal.c?
takayuki_ishii
Hello community,
In source code drivers/thermal/imx_thermal.c, to calculate temperature from TEMPMON count value,
it is used following formula in function imx_get_temp()
/* See imx_init_calib() for formula derivation */
if (data->socdata->version == TEMPMON_IMX7D)
*temp = (n_meas - data->c1 + 25) * 1000;
else
*temp = data->c2 - n_meas * data->c1;
In this formula, it is use data->c1, data->c2 constant values.
It is calculate in function imx_init_calib().
In this time, 3 fixed value (15423, 4148468, 28581) are used.
How to calculate this values?
OCOTP_ANA1 value of my imx6qp SABRE-SD board is 0x5724cd7d
So,
ROOM_COUNT=1394 [0x572]
HOT_COUNT=1229 [0x4cd]
HOT_TEMP=125 [0x7d]
I can't calculate c1, c2 value because I can't calculate 15423 and 4148468 from OCOTP_ANA1 value.
The other hand, where come from T1' = 28.580661 °C used in the kernel source code?
https://source.codeaurora.org/external/imxsupport/linux-imx/tree/drivers/thermal/imx_thermal.c?h=kor...
Ishii.
b36401
As noted in i.MX6QP Reference Manual calculation formula of Tmeas is:
T2 - (Nmeas - N2) * ((T2 - T1) / (N1 - N2))
The temperature calibration point fuse values are available in the OCOTP_ANA1 register.
josephzhou1
do
Joseph Zhou Jianhui / Senior Embedded Software Engineer, Singapore
takayuki_ishii
Hello Joseph and NXP support members,
Thank you for your reply.
I found a reason of this change in "i.MX 6 Temperature Sensor Module"
Application Note AN5215 at following community thread.
https://www.nxp.com/docs/en/application-note/AN5215.pdf
https://community.nxp.com/t5/i-MX-Processors/Can-someone-point-me-to-the-cpu-temperature-sensor-cali...
Ishii.
b36401
b36401
There is 2 points approximation:
temp= ( n_meas - n1) + 25
where n1 is the fuse value for 25C (factory provided).
takayuki_ishii
Hello NXP tech support member,
I understand what are you saying.
And sorry for my less information.
I use i.MX6QuadPlus.
Your answer is for i.MX7.
It would be grateful if you could let me know a method for i.MX6QP..
Ishii.
takayuki_ishii
Hello  support member,
Sorry but I can't understand what are you saying.
I hope to know why is it use fixed value 15423 and 4148468 in imx_thermal.c?
I think that it must calculate from the fuse value for 25C and HOT_TEMP (factory provided).
I add following dev_info message to output OCOTP_ANA1 and TEMPMON_TEMPSENSE0 register value to imx_thermal.c.
In function imx_init_calib()
n1 = ocotp_ana1 >> 20;
temp64 = 10000000; /* use 10^7 as fixed point constant for values in formula */
temp64 *= 1000; /* to get result in °mC */
do_div(temp64, 15423 * n1 - 4148468);
data->c1 = temp64;
data->c2 = n1 * data->c1 + 28581;
#ifdef TEMPMON_DEBUGOUT
dev_info(&pdev->dev, " ocotp_ana1=0x%08x data C1=%d, C2=%d\n", ocotp_ana1, data->c1, data->c2);
#endif
In function imx_get_temp()
else
dev_info(&tz->device, "TEMPMON0=0x%08x TEMP_CNT=0x%04x TEMP=%d\n", val, n_meas, *temp);
And OCOTP_ANA1 message log as following.
[ 3.719692] imx_thermal 20c8000.anatop:tempmon: ocotp_ana1=0x5724cd7d data C1=576, C2=831525
thermal_zone0/temp value as following.
$ cat /sys/class/thermal/thermal_zone0/temp
[ 29.159066] thermal thermal_zone0: TEMPMON0=0x4db56106 TEMP_CNT=0x0561 TEMP=38373
38373
In this time,
TEMPMON_TEMPSENSE0 = 0x4db56106
n_meas=0x0561=1377
OCOTP_ANA1 = 0x5724cd7d
n1 = 0x572 = 1394
Ishii.
