How to calculate RS-485 data rate ?
1,717件の閲覧回数
Raana
Dear Team,
Right now I'm using i.Mx8qxp based custom board.
There I want to develop the Test application to calculate RS-485 data rate.
I'm new to RS-485.
Can any one guide me to move further?
Is there any command or calculation or algorithm to achieve this?
Thanks in Advance.
Thank You.
J.P.Raja
4 返答(返信)
1,637件の閲覧回数
Rita_Wang
As the linux BSP for i.MX8QXP do not support, so for the RS 485 using you can use the Sensing IO direction Automatically via hardware, don't need to tune software. The follow is used on i.MX6, you can refer to .
1,637件の閲覧回数
Rita_Wang
Could you tell us which version of BSP are you using?
1,637件の閲覧回数
Raana
Hi Rita Wang,
Thanks for your response.
I'm using the "imx-yocto-L4.14.98_2.0.0_ga" version.
Thank You.
J.P.Raja
1,637件の閲覧回数
Rita_Wang
You can connect two RS-485 module to test the rate.
