Hi community,
I have a question about i.MX6 AUDMUX setting.
Please see the attached file, I want to know how should I set AUDMUX_PTCR and AUDMUX_PDCR with the use case.
I write the my guess setting value (PTCR & PDCR for port 2 and port 4) in the attached file also.
Is the setting correct?
If it is wrong, would you let me know what value should I modify?
Satoshi Shimoda
Solved! Go to Solution.
Hi Satoshi
I think settings are correct, except:
PTCR2:
RFSEL[20:17]=1011 (1xxx - select from RX port)
RCSEL[15:12=1011
PDCR4:
RXDSEL[15:13]=001
Hi Satoshi
PTCR2:
RCSEL[15:12=1011
PDCR4:
RXDSEL[15:13]=001
Hi Igor,
Thank you for checking.
And I found a mistake by my self.
I should set SYNC = 0b (async mode) if input RXC and RXFS from external device, shouldn't I?
Satoshi Shimoda
Hi Satoshi
you are right
