How set GPIO high at boot time on imx6ul
1,347件の閲覧回数
mihaitaivascu
     I would need to set some TAMPER GPIOs at boot time: MX6UL_PAD_SNVS_TAMPER4__GPIO5_IO06, e
 tc
     It is enough to do it in the barebox device tree setting them ACTIVE HIGH. If so where exactly in the device tree?
     Also I am trying to assign some signals to different GPIOs as the default GPIOs are used by other kernel modules.
     I could not find programming model for imx6ul or GPIO details in the hardware manual/application processor manual.
     Could somebody point me to the imx6ul documentation that explains GPIOs registers and functions ?
      Mihaita
3 返答(返信)
938件の閲覧回数
Hi Mihaita
I am afraid it is not possible to set gpio level in device tree setting, one can set it in
uboot/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c or in plugin, if using plugin mode.
Chapter 26 General Purpose Input/Output (GPIO) i.MX6UL Reference Manual
http://www.nxp.com/docs/en/reference-manual/IMX6ULRM.pdf
For linux documentation one can look on documents provided on
i.MX Software|NXP
938件の閲覧回数
mihaitaivascu
Hi Igor,
       Thanks for your answer.
       I saw some examples where gpios were set high in device tree. The following will not do it?
    Also I have looked at the imx6 manual but there is no programming model for it. I need to know the programming model for the imx6ul.
     For example I have some GPIOs that I wanted to use for something but I see some kernel modules are already using them so I need to see which other GPIOs/ signals can be used for power or Wifi, etc. Also I need to know the GPIO registers mapping in memory. And the GPIO functions.
     I could not find that information so far on NXP resources. In that document I found only this about GPIOs Tamper:
      Mihaita
938件の閲覧回数
Hi Mihaita
you can get additional details (in particular for "enable-gpios") in linux/Documentation/devicetree/bindings
documentation. Tamper pins are described in
Security Reference Manual for the i.MX 6UltraLite Applications Processor  (moderated link)
https://www.nxp.com/webapp/sps/download/mod_download.jsp?colCode=IMX6UL-SRM&appType=moderated&Parent...
