How do I do I SD_VIDEO from TVE to display in the NTSC waveform
daisukekitsunai
Hello Thank you for reading
I have been developing a custom board based on the QSB now.
And, I have to initialize the input and output of the video now.
TVE output destination is SD_VIDEO. By modifying the value of
the input clock to the chip, here is able to output to the TV color
bars.
However, the image will not be output when the input signal from
the outside of NTSC.
NTSC is that the normal waveform is observable.
waveform that is input to the CPU?
Can you provide instructions and a sample program?
Labels (2)
imxcommunitysco
Senior Contributor II
Customer also enterred a SR for this question. The SR was closed.
