How can enable uart-2 in ATF on i.mx8m mini platform, and boot Customer OS bin file
Search instead for
LeonGu
How can enable uart-2 in ATF on i.mx8m mini platform, and boot Customer OS .bin file.
igorpadykov
Hi Xudong
proper uart2 rdc permissions can be provided in atf codes (configuration is done on lines 312 - 314)
https://source.codeaurora.org/external/imx/imx-atf/tree/plat/imx/imx8mm/imx8mm_bl31_setup.c?h=lf-5.4...
