How can I connect a MEMS digital microphone with a I2S interface to the I.MX6 SSI interface?
1,213 次查看
massimopilia
nxp i.mx 6 ssi/i2s‌ mems‌
I'd like to connect a microphone like this one http://www.invensense.com/wp-content/uploads/2015/02/ICS-43432_DS.pdf, that is provided with a I2S interface, to the SSI interface of the I.MX6.
I saw in the i.MX 6Dual/6Quad Applications Processor Reference Manual, Rev. 3, 07/2015, that in Synchronous Mode (4-Wire Interface), each port will be a 4-wire interface (that is, RXD, TXD, TXC, TXFS). In this setup, receive data timing is determined by TXC and TXFS.
So, I'm thinking to use the following configuration:
  • TXC to provide the clock signal for the microphone
  • TXFS to provide the Word Select
  • RXD to receive the data from the microphone
  • TXD Not used!
Is it correct?
Thanks in advance!
Massimo Pilia
标记 (3)
909 次查看
igorpadykov
Hi Massimo
yes this understanding is right, it may be useful to check attached Porting Guide
Chapter 8 Porting Audio Codecs and Chapter 20 Porting Audio Codecs i.MX53 UG
http://www.nxp.com/assets/documents/data/en/user-guides/MX53UG.pdf
909 次查看
massimopilia
Thanks a lot Igor!!!
Massimo
