How can I connect a MEMS digital microphone with a I2S interface to the I.MX6 SSI interface?
1,215件の閲覧回数
massimopilia
nxp i.mx 6 ssi/i2s‌ mems‌
I'd like to connect a microphone like this one http://www.invensense.com/wp-content/uploads/2015/02/ICS-43432_DS.pdf, that is provided with a I2S interface, to the SSI interface of the I.MX6.
I saw in the i.MX 6Dual/6Quad Applications Processor Reference Manual, Rev. 3, 07/2015, that in Synchronous Mode (4-Wire Interface), each port will be a 4-wire interface (that is, RXD, TXD, TXC, TXFS). In this setup, receive data timing is determined by TXC and TXFS.
So, I'm thinking to use the following configuration:
  • TXC to provide the clock signal for the microphone
  • TXFS to provide the Word Select
  • RXD to receive the data from the microphone
  • TXD Not used!
Is it correct?
Thanks in advance!
Massimo Pilia
タグ(3)
2 返答(返信)
911件の閲覧回数
igorpadykov
Hi Massimo
yes this understanding is right, it may be useful to check attached Porting Guide
Chapter 8 Porting Audio Codecs and Chapter 20 Porting Audio Codecs i.MX53 UG
http://www.nxp.com/assets/documents/data/en/user-guides/MX53UG.pdf
911件の閲覧回数
massimopilia
Thanks a lot Igor!!!
Massimo
