Hi folks,
I'm trying to install and build LTIB as in the installation guide in the BSP, but I got the following error while building it;
Copying packages to /home/danny/ltib/pkgs
Installation complete, your ltib installation has been placed in
/home/danny/ltib, to complete the installation:
cd /home/danny/ltib
./ltib
danny@danny-beast:~$ cd /home/danny/ltib
danny@danny-beast:~/ltib$ ./ltib
sh: g++: not found
sh: tclsh: not found
ltib cannot be run because one or more of the host packages needed to run it
are either missing or out of date or not in ltib's standard path. Please
install/upgrade these packages on your host. If you have your own utilities
in non-standard paths, please add an entry into the .ltibrc file for example:
%path_std
/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/my/own/exes
Package Minimum ver Installed info
libstdc++ 0 not installed
gcc-c++ 2.96 not installed
zlib-devel 0 not installed
rpm 0 not installed
rpm-build 0 not installed
ncurses-devel 0 not installed
m4 0 not installed
bison 0 not installed
patch 0 not installed
tcl 0 not installed
Died at ./ltib line 1397.
traceback:
main::host_checks:1397
main:542
Started: Thu May 5 18:32:58 2011
Ended: Thu May 5 18:32:58 2011
Elapsed: 0 seconds
Build Failed
Exiting on error or interrupt
what should I do, then...
PS: I'm new to LTIB and even to Linux, so forgive me if that is a stupid question
解決済! 解決策の投稿を見る。
Hi Daniel,
I haven't seen these problems before, and I've used ltib on Ubuntu 9.04, so it can be done. What I would suggest at this point is to completely remove ltib (and the /opt/freescale directory), then re-install after making sure that your Ubuntu box is setup per the instructions in my second post on this thread.
If you don't want to run that script and instead manually figure out what to do, you should follow the steps here:
http://www.imxdev.org/wiki/index.php?title=ALL_Boards_ltib_config_ubuntu
After you have that setup, then install and re-run LTIB.
If you're still getting this problem, then go to freescale.com, login to "My Freescale", and click on Enter a Service Request to get an apps engineer from Freescale to help you out.
Mariano
Now it builds successfully...
Thanks a ton, Mariano!
Hi danix,
I got stuck in the same dbus problem has you did back then. Do you remember the steps that you did to solve the problem? If you could tell me I will be much appreciated!
Hi Daniel,
Mariano
Hey,
Can't get past the linker problem (ld can't find -lx11). It brings this up when it tries to build dbus
it been a week trying to figure out, what options do I have,...please share your experience
Not sure why you're having a library linker problem (ld can't find -lX11). One possible problem is that there ltib left some residual stuff when you ran it without all the necessary packages installed.
Pay very close attention to this post:
http://imxcommunity.org/group/ubuntutipsandtricks/forum/topics/building-ltib-in-ubuntu-1004
hey,
so, i configured ltib with "./ltib -m config" successfully. but when I run it "./ltib" after running for about 20 minuits it reported like this:
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/lib/gcc/arm-none-linux-gnueabi/4.1.2/../../../../arm-none-linux-gnueabi/bin/ld: cannot find -lX11
collect2: ld returned 1 exit status
make[2]: *** [dbus-launch] Error 1
make[2]: *** Waiting for unfinished jobs....
gcc -ffunction-sections -fdata-sections -g -O2 -Wall -Wchar-subscripts -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wcast-align -Wsign-compare -Wdeclaration-after-statement -fno-common -o .libs/dbus-send dbus-print-message.o dbus-send.o ../dbus/.libs/libdbus-1.so
creating dbus-send
make[2]: Leaving directory `/home/danny/ltib/rpm/BUILD/dbus-1.2.3/tools'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/danny/ltib/rpm/BUILD/dbus-1.2.3'
make: *** [all] Error 2
error: Bad exit status from /home/danny/ltib/tmp/rpm-tmp.7723 (%build)
RPM build errors:
Build time for dbus: 35 seconds
Failed building dbus
f_buildrpms() returned an error, exiting
traceback:
main:560
Started: Sat May 7 11:24:30 2011
Ended: Sat May 7 11:29:19 2011
Elapsed: 289 seconds
These packages failed to build:
dbus
Build Failed
How can I fix that....
BTW: Freescale's documentation sucks big time!... I missed the days I played with TI's and Atmel's products
Hey Mariano,
I run the script from the link you suggested, but after installing tons of packages it stops at
Installing mutter...
E: Couldn't find package mutter
I couldn't find mutter for Ubuntu 9.04 in the repository. Used mutter for other versions anyway, but it in turn requires
gtk+-3.0 or above which I couldn't find anywhere...ahh
What is the solution for these?
thanks
Thanks man,
Yes I'm using Ubuntu 9.04
By the way, if you're on Ubuntu, read this:
http://imxcommunity.org/group/ubuntutipsandtricks/forum/topics/another-ltib-installation
(and you should join the "Ubuntu Tips and Tricks" group if you haven't already)
