HT mode is not supported by imx6ul
1,210 次查看
surendradhobale
   While reading the imx6ul referance manual, observed HT mode is not supported by imx6ul. ( chapter 20 , ECSPI section)
This is 1 bit field  ECSPIx_CONREG register.
{ Hardware Trigger Enable. This bit is used in master mode only. It enables hardware trigger (HT) mode.
Note, HT mode is not supported by this product.
0 Disable HT mode.
1 Enable HT mode. }
For what purpose this bit is used ?  Is this related to native chip select, as native chip select driven by hardware only.
标签 (3)
853 次查看
Yuri
    ECSPI module (IP) in i.MX6 does not have HT implemented, since
 there are no corresponding trigger inputs.
Yuri
853 次查看
hrishikesh23
Hi Yuri,
Thanks for your reply.
But is this trigger some how associated with Native chip select.
853 次查看
Yuri
