GPIO: Problem leak current while default power up
搜索替代
406 次查看
neusch
Have the i.MX6 only internal 100k pull-up or additional a diode ?
Is it the only way to solve the problem, by use a lot of Level-Shifter or Switch with trie-status ?
314 次查看
Hi Mathias
current through 1K should be limited to 1-2mA
314 次查看
Hi Mathias
i.MX6 has esd protection diodes on pads.
also one can try to set external MCU outputs as logic "0".
314 次查看
neusch
Hi Igor,
that is correct. But i can't ensure this while power up.
Can you say something to this?
315 次查看
Hi Mathias
