For Upgrade Android jb4.3 ga with the latest GPU driver
yuuki
Senior Contributor II
Our customer referred to the following information and tried it.
https://community.freescale.com/docs/DOC-100351#comment-10841
However, the "Android.mk.def" is not found, which is described in drivers/mxc/gpu-viv/hal/kernel/Android.mk file.
They cannot build.
May I have advice?
ChucoChe
From the document owner:
"It is galcore build-out makefile, not used in built-in kernel, I removed it in the updated package,
you can ask customer to sync the latest package, or remove drivers/mxc/gpu-viv/hal/Android.mk file directly."
Michel
ChucoChe
Michel
yuuki
Dear Michel,
Thank you for your help.
Our customer succeeded in building.
Beset Regards,
