Flashing android using prebuild image imx 8M
Search instead for
mukrsh
Trying to flash i.mx 8M plus with android demo binaries using uuu tool but getting a continuous error with the flashing script. (using Linux 20)
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.138-0-g051a8fe
Success 0 Failure 1
1:14 1/ 2 [HID(W):LIBUSB_ERROR_IO ] SDPS: boot -f "uuu_imx_android_flash.sh"
mukrsh
little modification in the script and that worked
echo "uuu script generated, start to invoke uuu with the generated uuu script"
if [ ${daemon_mode} -eq 1 ]; then
    ./uuu -d /tmp/uuu.lst
else
    ./uuu /tmp/uuu.lst
fi
mukrsh
else
    ./uuu /tmp/uuu.lst
fi
mukrsh
still getting the same error:
@build-machine:~/mike-space/android/aosp/nxp/android-11.0.0_2.2.0_image_8mpevk$ sudo ./uuu_imx_android_flash.sh -f imx8mp -a -e
[sudo] password for mukesh:
This script is validated with uuu 1.4.139 version, it is recommended to align with this version.
dtbo is supported
dual slot is supported
dynamic parttition is supported
vendor_boot parttition is supported
generate lines to flash u-boot-imx8mp.imx to the partition of bootloader0
generate lines to flash partition-table.img to the partition of gpt
generate lines to flash dtbo-imx8mp.img to the partition of dtbo_a
generate lines to flash boot.img to the partition of boot_a
generate lines to flash vendor_boot.img to the partition of vendor_boot_a
generate lines to flash vbmeta-imx8mp.img to the partition of vbmeta_a
generate lines to flash super.img to the partition of super
Wait for Known USB Device Appear...
Error: fail open file: >/tmp/uuu.lst
also tried to echo manually,
build-machine:/tmp$ sudo echo uuu_version 1.4.139 > uuu.lst
bash: uuu.lst: Permission denied
nxf46838
Please make sure that you have UUU tool in the environment variable PATH. For Linux the executable will be uuu, you may download it here:
https://github.com/NXPmicro/mfgtools/releases/download/uuu_1.4.165/uuu
Even for a quick test you may place this file in the same folder as the android script.
Aldo.
nxf46838
I don’t know which command you have used for your test, but please try with the following:
This will flash the slot a to the eMMC with default features enabled (uboot and vbmeta)
Aldo.
