Facing problem with imx_rpmsg_tty driver when imx thermal driver is enabled
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hi All,
I am trying to bring up communication between A7 and M4 on imx7d based custom board.
When i modprobe imx_rpmsg_tty driver on A7 side, Kernel hangs after successful call of driver probe. After bit of debugging, I have found that, kernel hangs at,
int driver_probe_device(struct device_driver *drv, struct device *dev)
int ret = 0;
if (!device_is_registered(dev))
return -ENODEV;
pr_debug("bus: '%s': %s: matched device %s with driver %s\n",
drv->bus->name, __func__, dev_name(dev), drv->name);
pm_runtime_barrier(dev);
ret = really_probe(dev, drv); <== This calls imx_rpmsg_tty driver probe
pm_request_idle(dev); <== Kernel hangs here
return ret;
This happens only if IMX_THERMAL is enabled. If i disable IMX_THERMAL from kernel config, I am not facing above problem and A7-M4 communication works fine.
What can be the reason for this behavior?
On the side note, I am facing below problem also while boot up,
cpu cpu0: failed to get the regulator
imx7d-cpufreq: probe of imx7d-cpufreq failed with error -2
U-boot logs: (PMIC gets detected)
PMIC: PFUZE300 DEV_ID=0x30 REV_ID=0x11
but in linux sysfs,
there is no entry in /sys/bus/i2c/devices (Should PMIC regulators be there?)
I am mentioning all the things just in case if everything is connected somewhere?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello Jagdish Gediya,
Would it be possible for you to share the dts used for this implementation to give them a look?
