Facing problem with imx_rpmsg_tty driver when imx thermal driver is enabled
1,248 次查看
jagdishgediya
Hi All,
I am trying to bring up communication between A7 and M4 on imx7d based custom board.
When i modprobe imx_rpmsg_tty driver on A7 side, Kernel hangs after successful call of driver probe. After bit of debugging, I have found that, kernel hangs at,
int driver_probe_device(struct device_driver *drv, struct device *dev)
    int ret = 0;
    if (!device_is_registered(dev))
        return -ENODEV;
    pr_debug("bus: '%s': %s: matched device %s with driver %s\n",
         drv->bus->name, __func__, dev_name(dev), drv->name);
    pm_runtime_barrier(dev);
    ret = really_probe(dev, drv);               <== This calls imx_rpmsg_tty driver probe
  pm_request_idle(dev);                     <== Kernel hangs here
    return ret;
This happens only if IMX_THERMAL is enabled. If i disable IMX_THERMAL from kernel config, I am not facing above problem and A7-M4 communication works fine.
What can be the reason for this behavior?
On the side note, I am facing below problem also while boot up,
cpu cpu0: failed to get the regulator
imx7d-cpufreq: probe of imx7d-cpufreq failed with error -2
U-boot logs: (PMIC gets detected)
PMIC: PFUZE300 DEV_ID=0x30 REV_ID=0x11
but in linux sysfs,
there is no entry in /sys/bus/i2c/devices (Should PMIC regulators be there?)
I am mentioning all the things just in case if everything is connected somewhere?
标签 (4)
835 次查看
gusarambula
Hello Jagdish Gediya,
Would it be possible for you to share the dts used for this implementation to give them a look?
