Facing issue while flashing Uboot for imx8dx custom board(sd) using UUU
519 次查看
afridi20
Getting write protected issue while flashing using UUU with command sudo uuu -b sd imx-boot
Kindly suggest on this. Thank you in advance.
Error log:
Fastboot: Normal
Boot from USB for mfgtools
*** Warning - Use default environment for mfg+-----------------------------+
, using default environment
Run bootcmd_mfg: run mfgtool_args;if iminfo ${initrd_addr}; then if test ${tee} = yes; then bootm ${tee_addr} ${initrd_addr} ${fdt_addr}; else booti ${loadaddr} ${initrd_addr} ${fdt_;
Hit any key to stop autoboot: 0
## Checking Image at 83100000 ...
Unknown image format!
Run fastboot ...
auto usb 1
Detect USB boot. Will enter fastboot mode!
flash target is MMC:1
switch to partitions #0, OK
mmc1 is current device
Starting download of 3402752 bytes
downloading of 3402752 bytes finished
writing to partition 'bootloader'
Initializing 'bootloader'
Writing 'bootloader'
MMC write: dev # 1, block # 64, count 6646 ...
The SD card is locked. Can not write to a locked card.
mmc write failed
0 blocks written: ERROR
Writing 'bootloader' FAILED!
512 次查看
igorpadykov
Hi Sulaiman
from log: "The SD card is locked"  one can check lock switch on SD card.
In general recommended to try brand new SD/eMMC device and use latest
BSP and uuu tool :   https://github.com/NXPmicro/mfgtools/releases/tag/uuu_1.4.139
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
503 次查看
afridi20
Thank for you the reply @igorpadykov . But we are using micro sd card without write protect. Please help on this issue.
499 次查看
igorpadykov
